Advice installing CUCM and CUxN (v9.x) on VMware
paulavts1
Hi All,
I wil be installing both applications on UCS servers using ESXi. I would like to know the following:
  • Where to download the up-to-date OVA files
  • What are the best practices/considerations when installing both applications on VMware
In talking with a colleague he mentioned two key things to mention are reservations which have to be setup and LRO can anyone help with the points mentioned by my colleague and above.
I thank you in advance.
Paul
Jaime Valencia
Unified Communications  Virtualization Downloads (including OVA/OVF Templates)
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Downloads_%28including_OVA/OVF_Templates%29
And if you haven't reviewed all the info and requirements for UC on UCS, you'll need some time to review the docwiki
Unified Communications in a  Virtualized Environment
Reservations are configured in the OVA, LRO is discussed in the docwiki along with any other requirement.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
