10-17-2007 03:58 PM - edited 03-18-2019 07:57 PM
I support a customer who says that there are times when the AC app will automatically go "Online" or "Offline" without the user knowing it happened. I have since discovered that pressing the spacebar when the AC window is active will toggle between states. I beleive the users are hitting the spacebar and not realizing it, but they swear that's not the case.
Has anyone else seen these symptoms? Also, is there a way to either disable or change the shortcut keys within the AC?
The customer is using CCM 4.1.3sr3c.
Any help or comments would be appreciated.
10-17-2007 09:24 PM
haven't tried it but may be you can edit or disable the spacebar. See below
10-18-2007 03:31 AM
Thanks, I'll try that.
Has anyone else seen this issue that was not related to the space bar shortcut?
10-26-2007 12:31 PM
I have customer saying they are having the same issue. They are running CCM 3.3.5
I will let you know if I find any resolution.
