Audio text manager
getdan
I have downloaded the latest version of audio text manager along with visio 2016.
My problem is i do not have the create visio drop down. This is a new laptop running Windows 10  64 bit.
I also installed the ODBC drivers.
My old laptop was Windows 10 64 bit as well and i had the Visio option on there.
lindborg
We dropped the Visio diagram support out - too many TAC calls coming in for what is essentially a non critical feature.
I left the last version that supported it (build 45) out on the temporary download page here that you can get:
http://www.ciscounitytools.com/Temp/
NOTE: TAC doesn't support this and won't help if you have issues with the Visio diagramming.
lindborg
Thanks. that did it!
