adding DID on to soft phones
Tomparsons
Looking for the best practices on adding DID to Remote Agents using softphones on the laptop on an AnyConnect VPN.
Chris Deren
Build these phones as you would any other using either BAT (if doing many) or Copy/Super Copy or whatever method you are comfortable with.  If you are assigning new DID ranges to these phones then depending on how your dial plan is constructed you may need to add additional config such as Translation Patterns or configs to CUBE/GW, all depends on how things are built.
Jaime Valencia
As explained here, there is really nothing special around configuring a DID in CUCM Vs a non-DID/Internal number
https://community.cisco.com/t5/unified-communications/cucm-dids-incoming-call-ringing-on-specific-extensions/m-p/4043308
java
if this helps, please rate
Chris Deren
