09-11-2017 05:33 AM - edited 03-19-2019 12:46 PM
Hi guys,
I need some help here, I have a cuc cluster 9.x and I am trying to set up auto attendant but the edit tab on the the handler settings is not functional anyone had this issue and what is the cause?
Solved! Go to Solution.
09-11-2017 06:19 AM
Which browser are you using? I believe I've run into this issue with chrome...
09-11-2017 06:19 AM
09-11-2017 06:35 AM
Hi BradEast1,
Thank you it is a browser issue I have been using chrome without issue I have no idea what changed Mozilla did the trick.
