Battery-Reversal in MGCP
Rohit Khajuria
Hi Can anyone please tell me the function of the commands battery-reversal or battery-reversal answer ?
What I figured out from some sources is that FXO ports in loopstart mode normally disconnect calls when they detect a second battery reversal (back to normal). Use the no battery-reversal command on FXO ports to disable this action
But I dont understand the function and use of this command in an effective way.
Rohit
0 Replies 0
