BE6K installation
W S H FERNANDO
Level 4
Level 4
Hi Everyone
I need to install BE6K for customer, but customer has ordered software and Hardware separately, so ESXi and  OVA template is not available in hardware storage. can you please share the ova template for BE6k ? this will be a great help. I cant see any place to download BE6K ova..:(
Regds
2 Accepted Solutions
Jaime Valencia
All the OVA files are available under downloads on Cisco.com, log with the right set of credentials associated to access them. They're under each product, there's an OVA option.
java
if this helps, please rate
Because you're not looking under CUCM, UC-> call control -> CUCM
java
5 Replies 5
Jaime Valencia
java
W S H FERNANDO
Level 4
Level 4
Hi Jaime
Thanks, but I can't see the CUCM 10.0 ova on Cisco site :(
Screenshot attached.
Regds
java
W S H FERNANDO
Level 4
Level 4
Thanks Jaime, is this applicable for BE6K version 10 as well ?
Regds
The OVAs for any kind of deployment are there.
java
