BFCP over SIP trunk between two clusters
Abdull_Cisco
Hi guys
For your advises please I just would like to know if BFCP presentation share screen between clusters using Jabber desktops softwares are avaliable only using SIP trunk or it can be provided using Inter cluster H. 323
Thank you in advance for your always supports
b.winter
as already discussed in your other post, there is no need today to still use H.323. Only to systems, that maybe only support H.323, and not SIP.
Just use a standard SIP trunk.
To answer your question: No, it's not supported.
"Presentation sharing using BFCP is supported only on BFCP enabled SIP networks. The entire network, including the endpoint devices and trunks, must be SIP."
--- Please rate this post as "Helpful" or accept as a solution, if your question has been answered ---
b.winter
