Bulk Reset tool
josephwuwu
Level 4
Level 4
Having some problems with the bulk reset tool. I tried logging in with both the unityinstall and unitymsgstoresvc account but am getting 4 errors when I run the bulk reset tool. I have checked and both account have Exchange full adminstrative rights.
(error):429 (ActiveX component can't create object) in procedure RemoveSubscriberMessages of Form frmResetSubscribers
(error):91 (Object variable or With block variable not set) in procedure RemoveSubscriberMessages of Form frmResetSubscribers
(error) could not log into mailbox with SMTP address=jsmith@xyz.com and Exchange server name=xyz-Ex. Make sure you are logged into the system with an account that has send as/receive as and full mailstore rights on all mailstores that home subscribers.
(error) mailbox messages for subscriber could not be removed.
Removing subscriber from SQL
Directory sync complete for removal
Adding subscriber back to SQL with new template settings
User created in SQL
Updating global subscriber table with new ObjectID values
Subscriber synch with directory started.
Directory sync complete for creation
5 Replies 5
lindborg
Unity version?
Bulk Reset version?
right off hand it sounds like the CDL libraries aren't installed on the box for some reason...
Unity Version 4.0.3. The Bulk Reset tool is the latest on the site (1.0.4)
As near as I can tell the CDO libraries are not installed on the server for some reason - which is a bit odd since they should always be on there - tools lke MSM use them to get at the mailstore as well. I'm a bit tied down with some short term deliverables or I'd cut you a debug version to test with but you might try going out to Microsoft and making sure you have the latest CDO (Collaborative Data Objects) libraries installed so the tool can get at the mailbox using them.
Installed on our Unity server or the Exchange server?
The Unity server - it's the set of libraries used to access the mailstore (on or off box).
