Call forwarding offnet doesn't insert 1 for non-local calls
Joseph Hiatt
When users at a remote site (long distance) call over the WAN to a central site phone that is call forwarded to a number local to the central site.  The remote site phone is sent through its voice gateway and the calls fails because the CallManager or gateway doesn't insert a 1.
Right now a special calling search space is configured on the central site phones that send call forwarded calls to the central site gateways.
What other ways could we accomplish the same thing.  Voice translation patterns on the gateways, etc?
yhung
There are multiple places you can do digit manipulation, like you mentioned you can do it on voice translation patterns applied on dial peers on the gateway, if you have CUCM, you can also do digit manipulation on route patterns or also on route lists.
Not sure if this is what you were looking for.
