Call Handler help
nixon1234
We just set up greetings for all of our offices. Each one is a bit different but what happens is when someone calls in from outside and hears the message they have the option to leave a message in the general mailbox if they hold. So if you hold it replays the same greeting then lets you leave a message. SO it looks like it is using the same greeting for the general greeting and the general mailbox. Would I have to create a new call handler and record a greeting like "general mailbox" and have the main call handler send to that general mailbox call handler or is there some easier way? Confusing I know but I could use some help.
17 Replies 17
I re look at this with fresh eyes and you are correct, reprompt at the call handler
thank you!!
Great! you are very welcome.
William,
If you still can't figure it out, it may be time to open a TAC case and just have someone jump onto the system and take a look.
Brad
