Call Handlers - Unity 7.02
Jim Augherton
Currently running Unity 7.02, I'm trying to configure a CH to transfer callers to an extension not associated with VM. I've configured the Transfer incoming calls to a phone to (Yes, ring this extension) when pushing the number associated with CH the response comes back with Example Administrator but doesn't connect to the number.  Not sure why this is working, any input would be greatly appreciated.
Thanks Jim
13 Replies 13
Rob Huffman
Hi Jim,
It looks like the same issue as in this thread
https://supportforums.cisco.com/message/3004221#3004221
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Thanks Rob for the link, that’s what I’ve tried to do – but getting the same EA not available.
Jim
Rob Huffman
Hi Jim,
Did you follow the steps listed by Tommer and Mr. Lindborg in regards
to creating a second Call handler and adjusting the Transfer restriction
tables?
Maybe you could describe the call flow (with numbers) so we can try to
help troubleshoot.
Cheers!
Rob
Calling dials into a main menu – listen to all the press options – the select an option that doesn’t have a VM attached to it. For ease 1234, I’ve created a CH to allow 1234 to be accessed. Going into main menu (caller Input) selecting option 1, assign CH to 1234, save, then click on the CH to go to 1234’s CH. Then go to call transfer and select Yes, ring this extension (1234). Make a test call – sorry EA is not available enter your ID followed by pound.
An under the caller input what do you have????
Attempt transfer??? or send to greeting???
Should be the first one if you expect to ring a phone.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Attempt Transfer
Attached are two screen shots – hope this helps clarify settings.
Thanks Jim
By any chance isn't the alternate greeting enabled on that 2357 call handler??
Or any other that's not the std greeting??
java
java
I tried using all the options, but it’s currently on standard greeting – I see no reason why this doesn’t work.
Jim
Rob Huffman
Hi Jim,
Is it possibly this bug?
CSCtc23262 Bug Details Bug #19 of 21 | < Previous | Next >
Transfer to CH from Forwarded Routing rule do not work correctly
Symptom:
The Call Handler's Owner's greeting is played instead of ringing the specified number which is set under the call transfer rules for the call handler when the call is transferred via a forwarded routing rule.
Conditions:
Call transfer to a Call Handler via a Forwarded Routing rule.
Call Transfer setting for the Call Handler set to "Yes, ring this extension" with an extension entered.
Call Handler has an extension. Optional  Extension field not blank.
Workaround:
Under Call Transfer, select "Yes, ring extension for:"
Save
Make a call so that is it hits the Forwarded Routing Rule
Change it back to "Yes, ring this extension" with an extension entered.
Save
It will now work
StatusStatus
Fixed
Severity Severity
3 - moderate
Last Modified Last Modified
In Last Year
Product Product
Cisco Unity Unified Messaging
Technology Technology
1st Found-In 1st Found-in
7.0(2)ES1
Fixed-In Fixed-in
Release-Pending
Cheers!
Rob
Rob, thanks for all the time and effort you’re putting into this – that’s exactly my problem – but the workaround still didn’t fix my problem. I’m going to TAC in now to see if there’s and ES my version (8.6) of software to fix this .
Jim
Rob Huffman
Hi Jim,
You are most welcome
Please let us know the outcome here.
Cheers!
Rob
Thanks to all for the input - the solution was way to simple - whent Java mentioned to check the ALT transfer I did, the problem was just that the ALT transfer was enabled - which over ruled the rest of the options - when I disabled it on all the CH they started working.  Once again thanks.  Leason learned check ALT Xfer first.
Happy New Year to all.
JIm
