Call not ringing in all the devices
ben Zecharia
Hello ,
Recently  I installed MRA for one of my clients right now the client testing the soultion . We experience some weird problem with
the Iphone client (android not tested yet).Sometimes when calling an extension the desk phone is ringing and the iphone client is
not ringing(and dont see the call)  you can see this beavior  in the logs attached .After few minutes the Iphone clieny may log missed call
or just start to ring
Any idea ?
Ryan Huff
Level 4
Level 4
So where does MRA fit in this scenario? Are you saying the the desk phone and the iPhone are both on the inside of the network and someone is calling externally, via MRA and the deskphone and iPhone Jabber client should be ringing at the same time?
-Ryan
The issue occur only to the iphone device . It's connected to the CUCM through the MRA.
I am not sure if the MRA  is part of the problem.
BenBen
Hi Ben,
Did you finally find out the reason for your issue? I saw similar issue as well.
Thanks.
