Caller ID issue
Koiser_Nicholas
Am running CM 4.2.
GSM calls are made via the Quescom GSM gateway.The quescom is registered as an H323 gateway.
Am able to make calls through the gateway without any problem.
The issue is the number is not displayed on the far end.The quescom is configured to send caller id.
All my othe configurations seem okay.
Anyone who's had such a problem before,how was it resolved.
Are there any configurations that are to be made on the callmanager?
testeven
Hi!
Get a debug isdn q931 and see if the provider is sending the caller-id via the Facility IE, if that's the case check this
bug: CSCdz72442 H225 CONNECT message does not pass Display IE
Symptom:
The name of the called party may not show up on an IP phone.
Condition:
This may happen when the called party on the PSTN answers a call, the router
receives a CONNECT message with the Display IE in Codeset 6. The router does
not send the Display IE in the H225 CONNECT message.
Workaround:
Could use MGCP or a different switchtype such as QSIG if possible.
You can check this TAC Case Collection too:
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K14016668
Teresa.
If you find this post helpful, please rate! :)
Regards, Tere. If you find this post helpful, please rate! :)
