Cause 41 on ISR4321 with BRI
akram.root
Level 4
Level 4
I have a cucm 12.5 integrated with gateway isr 4321 on H.323 , in this gateway i have a ISDN (BRI).
The problem happens , sometimes , sometimes not
when the problem happen it give the cause value  41 (Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
and i can hear the message of cucm : "your call cannot be routed".
You find in attachement the debug .
Best regards
11 Replies 11
Are you sending the right numbers to ISP ? I can see from the debug
Called Number=*0638884592 and Called Number=#0638884592.
Response Signature
yes , because i use those dial peer :
dial-peer voice 11 pots
description utliser pour les appels vers National avec #
destination-pattern #0[567]........$
progress_ind setup enable 3
progress_ind alert enable 8
direct-inward-dial
port 0/2/2
prefix 0
dial-peer voice 13 pots
description utliser pour les appels vers National avec *
destination-pattern *0[567]........$
direct-inward-dial
port 0/2/3
prefix 0
Best regards
Leo Arias
Cause code 41 indicates Temporarily Unavailable. Typically happens when you experience a network issue or sudden disconnection on the call path.
Your BRI interface seems to be flapping:
May 7 13:03:23.275: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/2/2:0, TEI 69 c hanged to up
May 7 13:03:23.462: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/2/2:0, TEI 69 changed to down
Then you immediately see the disconnection, so my guess is the flapping of the interface is causing the problem.
May 7 13:03:23.463: //18373/00654599F80F/CCAPI/cc_api_call_disconnected:
Cause Value=41, Interface=0x7FDC3E1C9B48, Call Id=18373
Thank you for your reply .
What do you suggest to me for solving this issue
Bes regards
sh controllers e1/t1 will give more informations. You can issue the command  clear counters and see if the values increment. Based on the error you may need to contact service provider and also you need to review  your configuration.
Response Signature
Thank you for your return   i have a BRI not a E1.
Best regards
Here you can find in attachment the output of the interfaces BRI.
Best regards
Open ticket  with your provider.
Response Signature
Provider telco or cisco tac ?
Best regards
Contact your telco.
Response Signature
I would suggest to check first with your provider.
If they don't see any fault on their end, it could be the cable or the card. Change the cable connecting the interface.
If this is an ISDN link you can enable debugs
debug bri-interface,
debug isdn q921 and
debug isdn q931
to see if there is any issue reported by the system before the link goes down.
