09-01-2011 03:06 AM - edited 03-19-2019 03:31 AM
Today I return from my vacation and noticed red light on CCM HDD!!
In system report I found this:
physicaldrive 1:1
Port: 2I
Box: 1
Bay: 1
Status: Failed
Please can someone advice me what to do? Can I repair this? Check some other thing?? I appreciate any advice.
Ivan
all report:
MCS Model | 7835H2 |
CPU Speed | 2333 |
RAM | 2G |
Partitions | Partition Name: / Total: 25331720K Available: 13569832K Used: 11504528K Unrestricted: False Partition Name: /partB Total: 25331752K Available: 13693880K Used: 11380512K Unrestricted: False Partition Name: /common Total: 88139580K Available: 45300620K Used: 38361648K Unrestricted: Not Supported |
RAID Configuration | Smart Array P400 in Slot 1 Bus Interface: PCI Slot: 1 Serial Number: PAFGK0R9VXJ05M Cache Serial Number: PA82C0J9VX50DL RAID 6 (ADG) Status: Enabled RAID 6 (ADG) Enabler Status: Enabled Controller Status: OK Chassis Slot: Hardware Revision: Rev E Firmware Version: 5.26 Rebuild Priority: Medium Expand Priority: Medium Surface Scan Delay: 15 sec Cache Board Present: True Cache Status: OK Accelerator Ratio: 50% Read / 50% Write Total Cache Size: 256 MB Battery Pack Count: 1 Battery Status: OK SATA NCQ Supported: True Array: A Interface Type: SAS Unused Space: 0 MB Status: Failed Logical Drive: 1 Size: 136.7 GB Fault Tolerance: RAID 1+0 Heads: 255 Sectors Per Track: 32 Cylinders: 35132 Stripe Size: 64 KB Status: Interim Recovery Mode Array Accelerator: Enabled Unique Identifier: 600508B10010523956584A30354D0001 Disk Name: /dev/cciss/c0d0 Mount Points: / 24.5 GB, /partB 24.5 GB, /grub 258 MB, /common 85.4 GB physicaldrive 1:1 Port: 2I Box: 1 Bay: 1 Status: Failed Drive Type: Data Drive Interface Type: SAS Size: 146 GB Rotational Speed: 10000 Firmware Revision: HPD0 Serial Number: D0A2P9703JB10928 Model: HP DG0146BARTP physicaldrive 1:2 Port: 2I Box: 1 Bay: 2 Status: OK Drive Type: Data Drive Interface Type: SAS Size: 146 GB Rotational Speed: 10000 Firmware Revision: HPD0 Serial Number: D0A2P9703JDT0928 Model: HP DG0146BARTP |
RAID Version | RAID Firmware Version: 5.26 RAID BIOS Version: N/A |
BIOS Information | 11/01/2008 |
09-01-2011 06:13 AM
You can try to run the latest FWUCD available for 7835-H2.
If that does not help, if this is a Cisco provided MCS server which is under contract/warrenty you should open a service request for the faulty part to be replaced. If this server was purchased from HP, you need to contact HP for replacing the parts.
09-02-2011 02:48 AM
Thank you on your replay. I will first study what I need to do... and next week I will try to upgrade.
