CCM disk problem???
Ivan Marinovic
Today I return from my vacation and  noticed red light on CCM HDD!!
In system report I found this:
physicaldrive 1:1
         Port: 2I
         Box: 1
         Bay: 1
       Status: Failed
Please can someone advice me what to do? Can I repair this? Check some other thing?? I appreciate any advice.
Ivan
all report:
MCS Model
7835H2
CPU Speed
2333
RAM
2G
Partitions
Partition Name:     /
         Total:     25331720K
     Available:     13569832K
          Used:     11504528K
  Unrestricted:     False
Partition Name:     /partB
         Total:     25331752K
     Available:     13693880K
          Used:     11380512K
  Unrestricted:     False
Partition Name:     /common
         Total:     88139580K
     Available:     45300620K
          Used:     38361648K
  Unrestricted:     Not Supported
RAID Configuration
Smart Array P400 in Slot 1
   Bus Interface: PCI
   Slot: 1
   Serial Number: PAFGK0R9VXJ05M
   Cache Serial Number: PA82C0J9VX50DL
   RAID 6 (ADG) Status: Enabled
   RAID 6 (ADG) Enabler Status: Enabled
   Controller Status: OK
   Chassis Slot:
   Hardware Revision: Rev E
   Firmware Version: 5.26
   Rebuild Priority: Medium
   Expand Priority: Medium
   Surface Scan Delay: 15 sec
   Cache Board Present: True
   Cache Status: OK
   Accelerator Ratio: 50% Read / 50% Write
   Total Cache Size: 256 MB
   Battery Pack Count: 1
   Battery Status: OK
   SATA NCQ Supported: True
   Array: A
      Interface Type: SAS
      Unused Space: 0 MB
      Status: Failed
      Logical Drive: 1
         Fault Tolerance: RAID 1+0
         Heads: 255
         Sectors Per Track: 32
         Cylinders: 35132
         Stripe Size: 64 KB
         Status: Interim Recovery Mode
         Array Accelerator: Enabled
         Unique Identifier: 600508B10010523956584A30354D0001
         Disk Name: /dev/cciss/c0d0
         Mount Points: / 24.5 GB, /partB 24.5 GB, /grub 258 MB, /common 85.4 GB
      physicaldrive 1:1
         Port: 2I
         Box: 1
         Bay: 1
         Status: Failed         Drive Type: Data Drive
         Interface Type: SAS
         Rotational Speed: 10000
         Firmware Revision: HPD0
         Serial Number: D0A2P9703JB10928
         Model: HP      DG0146BARTP
      physicaldrive 1:2
         Port: 2I
         Box: 1
         Bay: 2
         Status: OK
         Interface Type: SAS
         Serial Number: D0A2P9703JDT0928
RAID Version
RAID Firmware Version:  5.26
RAID BIOS Version: N/A
BIOS Information
11/01/2008
bvanturn
You can try to run the latest FWUCD available for 7835-H2.
If that does not help, if this is a Cisco provided MCS server which is  under contract/warrenty you should open a service request for the faulty part to be replaced. If this server was purchased from HP, you need to contact HP for replacing the parts.
Thank you on your replay. I will first study what I need to do... and next week I will try to upgrade.
