CCME XFER direct to VM CUE fails with reorder
shaftstri
CCME/CUE
We are trying to get reception to be able to transfer calls direct to VM
extension range is 712XX
VM pilot is 71210
We setup an ephone that forwards all to VM as below
Ephone-dn 47
number 871277
description Xavier direct to VM
call-forward all 71210
under Xavier's CUE mail box he has an e.164 num setup as 871277 as well as he's extension 71277
When someone calls the ephone-dn 871277 it should foward to CUE VM though it fails and user gets reorder
how can we rectify this issue ?
Markus Schneider
If you just call 71210, do you get voicemail? You should only get reorder if that number is not truely the pilot number. You can do a "debug ccsip message" from the CME router; it would also help to see the CUE and CME configuration (show run) to be certain.
