challenge with dial-peer selection,using voice class e164-pattern-map
I have experienced, that the correct inbound dial-peer is not selected, and the call not sent to an outbound dial-peer.
I'm using are rather long list, that seems to kick in, even though there is no match there but a match in another list with a wildcard.
Adding an excact match solves the problem
Config snip (pattern maps attached) :
Wrong dial-peer:
dial-peer voice 34114 voip
description *** VK156451 TDC to Cube for Voice ***
huntstop
session protocol sipv2
destination dpg 3411
incoming called e164-pattern-map 3411
Correct dial-peer:
dial-peer voice 34194 voip
description *** VK156451 TDC to Cube ***
incoming called e164-pattern-map 3419
fortvald
Jonathan Schulenberg
There actually is a match in map 3411:
e164 +45384881[058]
This doesn’t have the leading carrot and trailing dollar sign to denote start/end of line, so it allows partial marches. This is a closer match than the wildcard pattern you have in map 3419.
e164 +45384881[058]
Thanks, I missed that typo.
fortvald
