Change SMTP sender address Unity Connection 7.x
Tim Lambrecht
Level 5
Level 5
Our customer's SMTP smarthost will only allow incoming email with an SMTP sender address (From: field) in the format of xxx@customer.com. Unity Connection by default will set the sender address of the SMTP notifications to unityconnection@<hostname>.<domainname>. Is there any way we can set this sender address? I have checked all parameter configuration but could not find anything. Does someone know if it is possible to change the sender address?
Many thanks,
Tim
Brad Magnani
Tim,
Looks like you're trying to determine how to change the SMTP domain of the UC server.  Here's the process on how to do that.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag247.html#wp1131945
Step 5 To check the SMTP domain, expand System Settings > SMTP Configuration, then click Server.
Hope that helps,
Brad
