Changing admin user names on CUCM and Unity Connection
djbuechner_2
I have an installed CUCM and Unity Connection 8.6 system.  I need to change the admin userids both at the OS and application levels.  I've managed to change the application user on CUCM with the utils reset_application_ui_administrator_name command.  Said command doesn't appear to work on Unity.
On Unity I tried to create a new admin user which was successful.  Deleted the unwanted one gets me a message that this user can't be deleted.
I'm stymied on the OS side.
Any thoughts?
Thanks!
David
Jaime Valencia
You can't delete the users that are created during install.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
