Cisco Attendant Console Local Speed Dials migration to CUBAC
richard.grey
Hello Guys,
I have a customer that is moving to CUCM 8.0.3 fro Call Manager 4.1.3.  The customer currently uses the built in Call Manager Attendant console and have built a pretty extensive speed dial list with the application.  Is there a way to migrate / export / import these local speed dials from Call Manager Attendant Console in Cisco Unified Business Attendant Console 8.0.3?
Rich
benjaminwatt
Level 5
Level 5
I don't believe there is. We faced a similar issue moving to CUEAC from the Attendant Console that came with 6.1. I had to manually re-enter all this information again, and you'll find that the speed dials area of CUBAC is arguably not as good as it was in the old Attendant Console.
benjaminwatt
Level 5
Level 5
Tommer Catlin
If you can get it out into a CSV file or flat file, you might be able to massage it and import it into the CUBAC.  (enterprise version)
