01-14-2015 11:20 AM - edited 03-19-2019 09:02 AM
I am on version 8.6.2 for CUCM and Cisco Unity Connection. I recently updated my subscribers with bash, and I also did one unity connection. On the subscribers, I can log in to OS Admin click Show > Software, and I see the bash cop file.
In my Unity Connection server, I try to do the same, and I do not see the bash cop file. So, I tried the upgrade again because I thought it did not install correctly, and it says the file is there.
I am in a virtual environment.
I need some guidance on what I did wrong.
Thanks!
01-14-2015 12:24 PM
Try a "show tech version", that should show it installed as I recall...or show version active....
01-14-2015 12:54 PM
I used "show tech version", and I can see that the bash cop file has changed to a different version.
Why will the new bash file not show in OS Admin?
01-14-2015 12:56 PM
I don't know, it's something others were asking too. That was the best info I could provide you.
01-14-2015 01:15 PM
I have one more question. Can you confirm the new bash file version?
For me, the old bash file was 3.2(32.e15) to the new bash file 3.2(33e15_11.4).
01-14-2015 01:32 PM
The version running for me will be different since we are on different versions. bash 4.1.2(15.el6_5.2)
