Cisco IOS MTP drops calls after silence
Hi all. I have a SIP trunk connecting a CUCM 6.1 to an Avaya PBX. The CUCM engages a Cisco enh IOS MTP on a 3845 for DTMF conversion.
After call establishment, if there is no audio on the path (e.g. if both parties press the mute button) the MTP drops the call after 30-45 seconds.
I'm sure it's the MTP because the call is not dropped if I remove the MRG from the trunk configuration.
Is there any way to avoid this beaviour or to manage the timeout (if any)?
the codec configured on the mtp profile is g729br8 (g.729 annex B)
Massimiliano
I tryed by changing the codec to g729a and calls don't disconnect any more.
The issue should be related to media inactivity. There's any time out I can set?
Here a log trace from the router:
Pilot_MTP_4#sh debugging
RTP:
  RTP protocol debugging is on
SCCP:
  Skinny Client Control Protocol events debugging is on
VOIP RTCP Events debugging is on
VOIP RTCP Errors debugging is on
VOIP RTP Session Generic Events debugging is on
VOIP RTP NSE Events debugging is on
VOIP RTP ALL Named Events debugging is on
VOIP RTP Conference Events debugging is on
VOIP RTP Multicast Events debugging is on
VOIP RTP DTMF-RELAY Events debugging is on
VOIP RTP TEXT-RELAY Events debugging is on
VOIP RTP Errors debugging is on
CCSIP SPI: SIP Call Events tracing is enabled    (filter is OFF)
Pilot_MTP_4#debug ip udp
UDP packet debugging is on
Pilot_MTP_4#ter mon
Pilot_MTP_4#
Pilot_MTP_4#
Sep  2 14:38:34 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:38:34 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:38:37 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:38:37 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:38:39 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:38:39 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Pilot_MTP_4#
Sep  2 14:38:44 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:38:44 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:38:44 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:38:49 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:38:49 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:38:51 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:38:51 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:38:54 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:38:54 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:38:54 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:38:55 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:38:55 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:38:55 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:38:57 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:38:57 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:38:59 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=72
Sep  2 14:38:59 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:01 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:39:01 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:39:01 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:39:04 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:39:04 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:05 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:39:05 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:09 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:39:09 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:09 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:39:14 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:39:14 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:17 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:39:17 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:19 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:39:19 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:20 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:39:20 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:24 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=72
Sep  2 14:39:24 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:25 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:39:25 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:39:25 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:39:27 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:39:27 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:29 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:39:29 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:31 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:39:31 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:39:31 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:39:34 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:39:34 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:34 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:39:39 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:39:39 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:41 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:39:41 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:44 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:39:44 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Pilot_MTP_4#
Pilot_MTP_4#             MUTE ACTIVATE ON PHONE
Pilot_MTP_4#
Sep  2 14:39:45 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=140
Sep  2 14:39:45 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:49 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:39:49 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:52 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=96
Sep  2 14:39:52 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:54 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:39:54 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:55 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:39:55 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:39:55 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:39:59 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=96
Sep  2 14:39:59 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:39:59 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:40:01 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:40:01 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:40:01 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:40:04 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:40:04 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:04 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=96
Sep  2 14:40:09 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:40:09 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:12 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=96
Sep  2 14:40:12 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:14 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:40:14 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:17 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=96
Sep  2 14:40:17 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:19 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:40:19 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:22 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=96
Sep  2 14:40:22 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:24 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:40:24 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:25 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:40:25 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:40:25 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:40:28 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=96
Sep  2 14:40:28 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:29 CET: UDP: rcvd src=172.22.8.10(10705), dst=172.22.8.20(17707), length=96
Sep  2 14:40:29 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:31 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=96
Sep  2 14:40:31 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:31 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:40:31 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:40:31 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:40:33 CET: UDP: rcvd src=172.22.3.123(18105), dst=172.22.8.20(17995), length=56
Sep  2 14:40:33 CET: voip_rtp_get_gccb:Error, no gccb for callID:1000
Sep  2 14:40:33 CET: sym_xapp_search_for_conn_cb: sess_cb 682C7838, sess_id 33554776, conn_id 150995160
Sep  2 14:40:33 CET: sym_xapp_close_receive_chnl: sess_id 33554776, conn_id 150995160, cmode 3, nmode 3, event 3
Sep  2 14:40:33 CET: sym_xapp_calleg_modify_req: Info provided to RTPSPI - sess_mode 1, sess_id 33554776, conn_id 150995160, call_id 998
Sep  2 14:40:33 CET: voip_rtcp_map_mode: entered. rtp_mode = 0x1
Sep  2 14:40:33 CET: voip_rtcp_update_session: xmit fn=0x6101B360,
dstIF=0x67C6D790, dstCallID=1000, voip_mode=0x1, rtp_mode=0x1, ssrc_status=0, report_digits=0, tse-payload=0, need_new_ssrc=0
Sep  2 14:40:33 CET: IPIPGW: voip_rtp_update_callinfo, IP-IP DETECTED, in=9, out=27
Sep  2 14:40:33 CET: voip_rtp_update_callinfo: first_pak=TRUE, new_ssrc=0, type=1
Sep  2 14:40:33 CET:  voip_rtp_update_xmit_info
Sep  2 14:40:33 CET:  voip_rtp_update_xmit_info, dstvdbptr: 67C6D790, dstCallID 1000, gccb: 679D1B60, xmitFunc 6101B360,context 3E7
Sep  2 14:40:33 CET:  voip_rtp_update_xmit_info Xmit Info node current values xmit_info->dstvdbptr: 67C6D790, xmit_info->dstCallID 1000, xmit_info->xmitFunc 6101B360, xmit_info->context 3E7
Sep  2 14:40:33 CET:  voip xmit info count: 1
Sep  2 14:40:33 CET: voip_rtp_inactive_notification_update: session: 0x683BB7C0, new_request_mfactor: 0,                        rtcp_interval_unjittered: 1,                        inactive_callback: 0x62D96394,                        reactive_callback: 0x62D96574
Sep  2 14:40:33 CET: sym_xapp_unsubscribe_media_tone_relay: payload_type is invalid [0]
Sep  2 14:40:33 CET: sym_xapp_process_ccapi_events: state 4, eve_id 4, call_id 998
Sep  2 14:40:33 CET: sym_xapp_calleg_modify_success: Call modify success for sess_id 33554776, conn_id 150995160, call_id 998
Sep  2 14:40:33 CET: sym_xapp_suppress_cisco_resv_payload:
Sep  2 14:40:33 CET: voip_rtp_update_cisco_payloads:
Sep  2 14:40:33 CET: voip_rtp_update_cisco_payloads: The updated cisco reserved payload types are:
         cisco_codec_fax_pt = 128, cisco_codec_fax_ack_pt = 128,
         cisco_rtp_dtmf_relay_pt = 128, cisco_fax_relay_pt = 128,
         cisco_cas_pt = 128, cisco_clear_channel_pt = 128,
         cisco_rtp_type_annex_B = 128, cisco_lmr_tone_pt = 1636231852,
         cisco_nte_tone_pt = 4
Sep  2 14:40:33 CET: sym_xapp_stop_media_transmission: sess_id 33554776, conn_id 150995160, curr_mode 3, new_mode 1
Sep  2 14:40:33 CET: sym_xapp_calleg_bridge_destroy: for sess_type 1 sess_id 33554776 conn_id 150995160
Sep  2 14:40:33 CET: voip_rtcp_update_session: xmit fn=0x0,
dstIF=0x67C6D790, dstCallID=1000, voip_mode=0x1, rtp_mode=0x0, ssrc_status=0, report_digits=0, tse-payload=0, need_new_ssrc=0
Sep  2 14:40:33 CET:  voip_rtp_update_xmit_info, dstvdbptr: 67C6D790, dstCallID 1000, gccb: 679D1B60, xmitFunc 0,context 3E7
Sep  2 14:40:33 CET:  voip_rtp_update_xmit_info xmit_func is NULL
Sep  2 14:40:33 CET: sym_xapp_calleg_bridge_destroy: Bridge destroy initiated - bridge_cnt 2, sess_id 33554776, conn_id 150995160, bridge_id 665, call1_id 998, call1_type 1, call2_id 1000, call2_type 2, msp_clr_ref 0
Sep  2 14:40:33 CET: sym_xapp_process_ccapi_events: state 6, eve_id 13, call_id 998
Sep  2 14:40:33 CET: sym_xapp_calleg_bridge_destroyed: Bridge destroyed - sess_id 33554776, conn_id 150995160, bridge_id 0, call1_id 998, call1_type 1, bridge_cnt 1, msp_clr_ref 0
Sep  2 14:40:33 CET: sym_xapp_disconnect_calleg: Disconnecting calleg - sess_id 33554776, conn_id 150995160, calleg_id 998, calleg_type 1, state 7
Sep  2 14:40:33 CET: sym_xapp_calleg_disconnect_req: ccCallDisconnect made - sess_id 33554776, conn_id 150995160, calleg_id 998, calleg_type 1, state 8
Sep  2 14:40:33 CET: voip_rtp_stop_disc_timer
Sep  2 14:40:33 CET: voip_rtcp_remove_ccb
Sep  2 14:40:33 CET: voip_rtcp_send_event: event=EV_DESTROY
Sep  2 14:40:33 CET: voip_rtcp_destroy_idle
Sep  2 14:40:33 CET: voip_rtcp_close_session
Sep  2 14:40:33 CET: voip_rtcp_stop_session:
Sep  2 14:40:33 CET: voip_rtcp_stop_session: stop session
Sep  2 14:40:33 CET:
Sending RR for ssrc: 1606
cycles 0, max_seq 6017, base_seq 3,
total_expected 6015, expected_diff 6015,received_diff 6014,lost_diff 1, loss_fraction 0, actual_loss 1,
loss_value 1 ((0x1)
Sep  2 14:40:33 CET: UDP: sent src=172.22.8.20(17707), dst=172.22.8.10(10705), length=76
Sep  2 14:40:33 CET: Released port 17707 in Transport Port Agent for IP type 1
Sep  2 14:40:33 CET: Cleaning up sess=70F88B74, sp=17706, dp=10704
Sep  2 14:40:33 CET: RTP: Delete Session for APP(3): Success (70F88B74)
Sep  2 14:40:33 CET: RTP: Cleanup Session - Free member (70FAA9A8) for APP(3) Session(70F88B74)
Sep  2 14:40:33 CET: RTP: Cleanup Session - Free member (704095A0) for APP(3) Session(70F88B74)
Sep  2 14:40:33 CET: sym_xapp_process_ccapi_events: state 8, eve_id 14, call_id 998
Sep  2 14:40:33 CET: sym_xapp_calleg_disconnected: Calleg disonnected - sess_id 33554776, conn_id 150995160, calleg_id 998, calleg_type 1
Sep  2 14:40:33 CET: sym_xapp_transcoding_calleg_disconnected: for sess_id 33554776 conn_id 150995160 stream_passthr_id 16777216 calleg_type 1 msp_calleg_ref 0
Sep  2 14:40:33 CET: sym_xapp_disconnect_msp_calleg_if_needed: sess_id 33554776, conn_id 150995160 str_passthr_id 16777216,  rtp_clr 0x0, msp_clr 0x70F759F0, mm_msp_clr 0x0 peer_conn_cb 0x70F52D64
Sep  2 14:40:33 CET: sym_xapp_transfer_conn_cb_reference: MSP clr transfer ref in sess_id 33554776,
from cur conn_cb 0x70F52C90, conn_id 150995160, stream_passthr_id 16777216,
to peer  conn_cb 0x70F52D64, conn_id 150995161, stream_passthr_id 16777216
Sep  2 14:40:33 CET: sym_xapp_clear_conn_cb: conn_cb with sess_id 33554776, conn_id 150995160, sess_cnt 2 - is being removed
Sep  2 14:40:33 CET: sym_xapp_clear_rsvp:
Sep  2 14:40:33 CET: sym_xapp_search_for_conn_cb: sess_cb 682C7838, sess_id 33554776, conn_id 150995161
Sep  2 14:40:33 CET: sym_xapp_close_receive_chnl: sess_id 33554776, conn_id 150995161, cmode 3, nmode 3, event 3
Sep  2 14:40:33 CET: sym_xapp_calleg_modify_req: Info provided to RTPSPI - sess_mode 1, sess_id 33554776, conn_id 150995161, call_id 999
Sep  2 14:40:33 CET:  voip_rtp_update_xmit_info, dstvdbptr: 67C6D790, dstCallID 1000, gccb: 67CAEF00, xmitFunc 6101B360,context 3E6
Sep  2 14:40:33 CET:  voip_rtp_update_xmit_info Xmit Info node current values xmit_info->dstvdbptr: 67C6D790, xmit_info->dstCallID 1000, xmit_info->xmitFunc 6101B360, xmit_info->context 3E6
Sep  2 14:40:33 CET: voip_rtp_inactive_notification_update: session: 0x70FC9880, new_request_mfactor: 0,                        rtcp_interval_unjittered: 1,                        inactive_callback: 0x62D96394,                        reactive_callback: 0x62D96574
Sep  2 14:40:33 CET: sym_xapp_process_ccapi_events: state 4, eve_id 4, call_id 999
Sep  2 14:40:33 CET: sym_xapp_calleg_modify_success: Call modify success for sess_id 33554776, conn_id 150995161, call_id 999
Sep  2 14:40:33 CET: sym_xapp_stop_media_transmission: sess_id 33554776, conn_id 150995161, curr_mode 3, new_mode 1
Sep  2 14:40:33 CET: sym_xapp_calleg_bridge_destroy: for sess_type 1 sess_id 33554776 conn_id 150995161
Sep  2 14:40:33 CET:  voip_rtp_update_xmit_info, dstvdbptr: 67C6D790, dstCallID 1000, gccb: 67CAEF00, xmitFunc 0,context 3E6
Sep  2 14:40:33 CET: sym_xapp_calleg_bridge_destroy: Bridge destroy initiated - bridge_cnt 1, sess_id 33554776, conn_id 150995161, bridge_id 666, call1_id 999, call1_type 1, call2_id 1000, call2_type 2, msp_clr_ref 1
Sep  2 14:40:33 CET: sym_xapp_process_ccapi_events: state 6, eve_id 13, call_id 999
Sep  2 14:40:33 CET: sym_xapp_calleg_bridge_destroyed: Bridge destroyed - sess_id 33554776, conn_id 150995161, bridge_id 0, call1_id 999, call1_type 1, bridge_cnt 0, msp_clr_ref 1
Sep  2 14:40:33 CET: sym_xapp_disconnect_calleg: Disconnecting calleg - sess_id 33554776, conn_id 150995161, calleg_id 999, calleg_type 1, state 7
Sep  2 14:40:33 CET: sym_xapp_calleg_disconnect_req: ccCallDisconnect made - sess_id 33554776, conn_id 150995161, calleg_id 999, calleg_type 1, state 8
Sep  2 14:40:33 CET:
Sending RR for ssrc: E3037B
cycles 0, max_seq 21354, base_seq 8134,
total_expected 13221, expected_diff 13221,received_diff 13218,lost_diff 3, loss_fraction 0, actual_loss 3,
loss_value 3 ((0x3)
Sep  2 14:40:33 CET: UDP: sent src=172.22.8.20(17995), dst=172.22.3.123(18105), length=76
Sep  2 14:40:33 CET: Released port 17995 in Transport Port Agent for IP type 1
Sep  2 14:40:33 CET: Cleaning up sess=66E5B3D8, sp=17994, dp=18104
Sep  2 14:40:33 CET: RTP: Delete Session for APP(3): Success (66E5B3D8)
Sep  2 14:40:33 CET: RTP: Cleanup Session - Free member (70FD13DC) for APP(3) Session(66E5B3D8)
Sep  2 14:40:33 CET: RTP: Cleanup Session - Free member (70409794) for APP(3) Session(66E5B3D8)
Sep  2 14:40:33 CET: sym_xapp_process_ccapi_events: state 8, eve_id 14, call_id 999
Sep  2 14:40:33 CET: sym_xapp_calleg_disconnected: Calleg disonnected - sess_id 33554776, conn_id 150995161, calleg_id 999, calleg_type 1
Sep  2 14:40:33 CET: sym_xapp_transcoding_calleg_disconnected: for sess_id 33554776 conn_id 150995161 stream_passthr_id 16777216 calleg_type 1 msp_calleg_ref 1
Sep  2 14:40:33 CET: sym_xapp_disconnect_msp_calleg_if_needed: sess_id 33554776, conn_id 150995161 str_passthr_id 16777216,  rtp_clr 0x0, msp_clr 0x70F759F0, mm_msp_clr 0x0 peer_conn_cb 0x0
Sep  2 14:40:33 CET: sym_xapp_transfer_conn_cb_reference: conn_cb->peer_conn_cb is NULL, for  sess_id 33554776, conn_id 150995161, stream_passthr_id 16777216
Sep  2 14:40:33 CET: sym_xapp_disconnect_msp_calleg_if_needed: disconnecting MSP calleg for sess_id 33554776 conn_id 150995161 str_passthr_id 16777216
Sep  2 14:40:33 CET: sym_xapp_disconnect_msp_calleg_if_needed: Since this is the last connection disconnect the MSP calleg - call_id 1000
Sep  2 14:40:33 CET: sym_xapp_disconnect_calleg: Disconnecting calleg - sess_id 33554776, conn_id 150995161, calleg_id 1000, calleg_type 2, state 7
Sep  2 14:40:33 CET: sym_xapp_calleg_disconnect_req: ccCallDisconnect made - sess_id 33554776, conn_id 150995161, calleg_id 1000, calleg_type 2, state 8
Sep  2 14:40:33 CET: sym_xapp_process_ccapi_events: state 8, eve_id 14, call_id 1000
Sep  2 14:40:33 CET: sym_xapp_calleg_disconnected: Calleg disonnected - sess_id 33554776, conn_id 150995161, calleg_id 1000, calleg_type 2
Sep  2 14:40:33 CET: sym_xapp_transcoding_calleg_disconnected: for sess_id 33554776 conn_id 150995161 stream_passthr_id 16777216 calleg_type 2 msp_calleg_ref 1
Sep  2 14:40:33 CET: sym_xapp_clear_conn_cb: conn_cb with sess_id 33554776, conn_id 150995161, sess_cnt 1 - is being removed
Sep  2 14:40:33 CET: sym_xapp_clear_sess_cb: act_sess 0, act_conns 0, sess_id 33554776, appl_type 1
Sep  2 14:40:33 CET: sccp_check_for_swo_swb_and_tear_down: All connections are cleared - profile_id 1, appl_type 1, state 6, swo_init 0, swb_init 0
Pilot_MTP_4#
Pilot_MTP_4#
Pilot_MTP_4#
Pilot_MTP_4#
Pilot_MTP_4#
Pilot_MTP_4#
Pilot_MTP_4#
Pilot_MTP_4#
Sep  2 14:40:55 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:40:55 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:40:55 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:40:58 CET: UDP: rcvd src=93.18.251.37(123), dst=93.18.251.8(123), length=56
Sep  2 14:41:01 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:41:01 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:41:01 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:41:25 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:41:25 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:41:25 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:41:31 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:41:31 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:41:31 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:41:55 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:41:55 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:41:55 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
Sep  2 14:42:01 CET: sccpapp_process_timer_events: appl_type 1, experied_timer 3, xlated_eve 11, state 6
Sep  2 14:42:01 CET: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 1, state 6
Sep  2 14:42:01 CET: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
