Cisco jabber question
abd88elhak
i have CUCM 10.5 and presence 10.5 and cisco jabber 11.6.2
i have PC with jabber for windows installed . this pc is used by many users
when a user is connected with his account and  other try to connect with other account cisco jaber is rested
so is there any possibility to disable this option ?
best regards
5 Replies 5
Slavik Bialik
Level 7
Level 7
Yeah, it happens because UPN discovery is enable automatically by default. Uninstall Cisco Jabber, and install it with passing arguments to it, like that (via cmd):
msiexec.exe /i CiscoJabberSetup.msi CLEAR=1 UPN_DISCOVERY_ENABLED=FALSE
It'll disable the UPN automatic discovery. Means that from now on you'll have to enter the full user URI, like that: user@company.com, and only then you'll be prompted for the password.
Hi slavik
i uninstalled cisco jabber and installed it by CLI and tested with account  == ok
when i tried to change username i get reset message
i need sing in by other account without reset of cisco jabber is it possible ?
best ragards
No, there is no way to disable that, it's working as designed.
java
if this helps, please rate
Are you talking about the UPN auto discovery?
If so, you're wrong. I did it 2 weeks ago. Customer asked me for the ability to login with any jabber user, no matter which Windows user logged in. So I found that if you install Cisco Jabber with this parameter set to False, it does the job.
Unless this is not what you're talking about 😊
Strange, I did it two weeks ago and it worked. Maybe the Jabber 11.6 you're using doesn't have this feature (UPN_DISCOVERY_ENABLED) yet. I did it with 11.9.1 and it worked fine. Maybe you should try to install a newer version.
