Cisco Mobile 8.1 Desk Phone Integration
flex_serg
I am having problems with Cisco Mobile 8.1 Desk Phone Integration.
I've got CUCM 7.1.5, and iPhone with Cisco Mobile 8.1. When Desk Phone Integration is disabled, everything works fine. But when I enable it, iPhone returns an error: Verification Timeout. There is no AD integration set on CUCM, password and username are set manually and typed in iPhone correctly.
There is a firewall between Wireless network to which Cisco Mobile connects and CUCM. I think problem might be hiding there. So where can I see the list of rules that must be allowed on firewall for integration to work, if any. And if not, what else can prevent it from working.
Thanks a lot!
Jonathan Schulenberg
Be sure the CTI port TCP/2748 is allowed. Be careful of application inspection depending on the firewall; it uses CTI-QBE to perform deskphone control.
