06-20-2015 11:34 AM
Can I use Cisco Prime Collaboration standard for ISDN PRI monitoring or should I order the advanced edition
Prakash
06-22-2015 05:09 AM
Hello Prakash
Cisco Prime collaboration do support monitoring of PRI E1/T1. Please refer this link for more information.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/collaboration/10-6/assurance/standard/guide/Cisco_Prime_Collaboration_Assurance_Guide_Standard_10_6/Cisco_Prime_Collaboration_Assurance_Guide_Standard_10_6_chapter_01000.pdf
Lavanya
07-08-2015 06:19 AM
Hi Lavanya,
Thank you for your link I have further questions about the topic.
If I see it correctly the only monitoring status of a single E1 interface would be a MGCP E1 interface.
All other information for H323 and SIP trunks are an overall status and not dedicated to a special interface, is that correct?
In my opinion it would be great if you can monitor a dedicated interface on router (H323 or SIP gateway) but that is not possible, right?
best regards
Ben
