Cisco router error "ROMmon (rommon 1 >): " problem
medzeinmaaloum
Every day after starting my 3925 router, displays the message:
I reload the boot (boot flash: c3900-universalk9-mz.SPA.154-3.M3.bin) every time, is there a solution for this?
You need this in your config.
boot system flash flash:c3900-universalk9-mz.SPA.154-3.M3.bin
16 Replies 16
I haven't found a solution!
Please either share the complete router config, or at least part of it. If you want to do a partial config, do this.
show run | incl boot
It would also be helpful to know how the configuration register is set.
show version
Voice_Projets#show run | incl boot
boot-start-marker
boot-end-marker
license boot module c3900 technology-package uck9
Voice_Projets#
Voice_Projets#show version
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.4(3)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 05-Jun-15 15:47 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Voice_Projets uptime is 3 minutes
System image file is "flash:c3900-universalk9-mz.SPA.154-3.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE100/K9 with 997376K/51200K bytes of memory.
Processor board ID FJC2145D06Q
3 Gigabit Ethernet interfaces
1 terminal line
8 Voice FXO interfaces
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
245448K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 C3900-SPE100/K9 FOC2141376A
Technology Package License Information for Module:'c3900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 EvalRightToUse uck9
data None None None
NtwkEss None None None
CollabPro None None None
Voice_Projets#
Voice_Projets#
Ok, how?
any progress about that?
Good evening,
The problem "ROMmon (rommon 1 >): is not solved yet, each time I start my router it displays the message:
ROMmon (rommon 1 >
I have to load the image each time:
When I said "put this in your config", that means "config t" and enter the command I gave you and write it.
Good day,
I ran the command yesterday:
Voice_Projets(config)#
Voice_Projets(config)# boot system flash flash:c3900-universalk9-mz.SPA.154-3.M3.bin
Voice_Projets(config)#do write
Building configuration...
[OK]
And when I start the router this morning it still displays the same message, I had to load the image again c3900-universalk9-mz.SPA.154-3.M3.bin :
monitor: command "~" not found
rommon 2 >
Disconnect the cable from the console (and aux port if applicable), then power cycle the router. Does it boot correctly then?
yes when I disconnect the cables from the router it starts without problem
Then your serial port or your terminal emulation program is generating some kind of output during the boot process that is interrupting it.
so is, how can i solve this?
