Cisco UC Integration for Lync 9.7x EOL
douglascote
Greetings,
Can anyone tell me what the end-of-life/support date is for Cisco UC Integration for Microsoft Lync v9.7x? I found a bulletin pertaining to v9.2x and the EOL date, but nothing for v9.7x. Any assistance you can provide is appreciated.
Doug
2 Accepted Solutions
Jaime Valencia
I couldn't find anything public facing googling that, it just might be there's still not a defined date, if you want further information, you would need to engage your SE/AM to get that information.
java
if this helps, please rate
Deepak Rawat
Doug,
If you will check the below document for Microsoft Lync Version 9.2x, there is a line in it "New orders for Cisco® UC Integration for Microsoft Lync version 9.2x software are already being filled with version 9.7x."
http://www.cisco.com/c/en/us/products/collateral/unified-communications/uc-integration-tm-microsoft-lync/bulletin-c25-735640.html
What this means in that 9.7x is going to be there and should be used for integrating with UC going forward. Secondly, whenever Cisco will announce the EOS/EOL date for UC integration with Microsoft Lync Version 9.7x the documents will be updated accordingly as well so you can check them then.
Deepak
- Rate Helpful Posts -
Jaime Valencia
java
Deepak Rawat
Doug,
Deepak
douglascote
Thanks for the quick responses.
