06-29-2016 01:35 PM - edited 03-19-2019 11:18 AM
Does anybody know if it is officially supported. I would assume so but I cant really find any stating that it is if you meet xyz requirements.
Solved! Go to Solution.
06-29-2016 02:06 PM
06-29-2016 02:06 PM
12-23-2016 07:32 PM
I would like to know the answer to this is well but the link provided say's that I am unauthorized. Is there any publicly available document that outlines using cisco UC applications on Hyperflex?
"Access to this place or content is restricted. If you think this is a mistake, please contact your administrator or the person who directed you here."
12-24-2016 12:10 PM
The problem is that the link points to a Cisco Partner discussion, most likely your CCO is not partner level.
The answer is pretty straight forward, the link goes into a bit more detail:
As far as the Collab apps are concerned, hyperflex is considered to be a specs-based-UCS
