Cisco UCM Self Care Portal - drag/drop to change speed dial order
johnhuspeni
Level 5
Level 5
FEATURE REQUEST
Please update the Self Care page so that speed dials can be reordered by drag & drop.
This would be marvelously efficient compared to the current method.
Also, please update the labels of the speed dial fields:
 - 'Number/URI' should be called 'Phone Number/URI'
 - Label is good
 - 'Speed Dial' should be 'Position'
Apologies if this is posted in the wrong area, please advise if so.
Thanks!
A Google on cisco collaboration aha gave me this.
https://ciscocollabcustomer.ideas.aha.io/
Response Signature
The community is not the appropriate place for feature requests. Those are best handled by your account team or by posting a suggestion on aha. If you do please check if there are a previously created suggestion and up-vote it before you create your own.
Response Signature
Hi Roger,
I have emailed my account team.  Can you please direct me to 'aha'?  Thank you,
John
Response Signature
