Cisco Unified Communications Manager Group configuration
Rosa Ladeira
Cisco Unified CM Administration -  System version: 7.1.5.10000-12
Cluster has 2 CUCMs: CM voip1 and CM voip2.
CM voip1 is the publisher and CM voip2 is the subscriber.
When adding a new group, just one CUCM (CM voip1) is shown available for selection on dropbox "Available Cisco Unified Communications Manager".
I want two options for Cisco 2811.
What I must configure to have both CUCMs on the dropbox?
Rosa
26 Replies 26
Ooooooooooops ! Something very strange
before and after "successful stop" and after restart License Manager its status remain Starting
Problems with ntp.  Do you known any cli command to adjust ntp.
no success on changing ntp server from web interface
admin:utils diagnose fix
Log file: platform/log/diag5.log
Starting diagnostic test(s)
test - disk_space          : Passed
skip - disk_files          : This module must be run directly and off hours
test - service_manager     : Passed
test - tomcat              : Passed
test - tomcat_deadlocks    : Passed
test - tomcat_keystore     : Passed
test - tomcat_connectors   : Passed
test - tomcat_threads      : Passed
test - tomcat_memory       : Passed
test - tomcat_sessions     : Passed
test - validate_network    : Passed
test - raid                : Passed
test - system_info         : Passed (Collected system information in diagnostic log)
test - ntp_reachability    : Failed
The host 147.65.30.7 is not reachable, or it's NTP service is down.
None of the external NTP servers have NTP service accessible
from this host.
Recommended solution:
You can either delete all external NTP servers and use the local
System clock, or you can add valid reachable NTP servers of clock
strata between 2 and 5.
Please use the OS Admin GUI to add/remove NTP servers.
test - ntp_clock_drift     : Passed
test - ntp_stratum         : Failed
The reference NTP server is a stratum 11 clock.
NTP servers with stratum 5 or worse clocks are deemed unreliable.
Please consider using an NTP server with better stratum level.
Please use OS Admin GUI to add/delete NTP servers.
skip - sdl_fragmentation   : This module must be run directly and off hours
skip - sdi_fragmentation   : This module must be run directly and off hours
test - ipv6_networking     : Passed
Diagnostics Completed
admin:
In CLI, you can use the utils ntp server add/delete commands to modify that configuration.
It seems that version 7 does not have this comand:
admin:utils ntp
      utils ntp config
      utils ntp restart
      utils ntp start
      utils ntp status
Are logged into the OS GUI of the Publisher?
Yes via SSH to publisher
I have figured out that, all this trouble started when network administrator asked to change publisher/subscriber subnet.
In addition publisher reboot had shown a kind of disk error that I was unable to precisely identify.
First of all, colleague had only changed main IPs on each server though provoking publisher/subscriber unable to talk each other (their secondary publisher/subscriber IPs were not changed). After ajusting thier secondary IPs I am having this old ntp server ip boring my environment. I tried to have it changed via web interface, but it was an unsuccessful trie.
Perhaps another publisher reboot may help. I do not know.
Sounds like a number of variables here adding up to a headache.  Disk/firmware errors were not uncommon on certain server models in 7.1(x).  If you post search for the error you received, you may well find it in the forums and/or the Cisco bug toolkit.  If this a new install, I would recommend that you consider a fresh start, replan the install, and maybe upgrade to a more recent version like 8.6 or even 9.1 at this point.  Of course, there are other considerations in that as well but might not be a bad idea.
Good luck!
That is the point I was thinking about.
Can I reuse those licenses after upgrading servers version ?
Major version upgrades require current UCSS support and feature licensing so no, you cannot simply reuse those licenses to upgrade to a new version. You would also need a new license if you change hardware on the Publisher.
Uauu! buying a new version turn things a little bit hard to solve.
Re-installing 7.1 maybe an alteranative forced choise.
Even thouth if everything goes wrong .... someone may decide on upgrading.
Thanks a lot.
Rosa
admin:utils dbreplication status
-------------------- utils dbreplication status --------------------
Replication status check is now running in background.
Use command 'utils dbreplication runtimestate' to check its progress
The final output will be in file cm/trace/dbl/sdi/ReplicationStatus.2013_02_08_19_59_27.out
Please use "file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_02_08_19_59_27.out " command to see the output
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: Only available on the PUB
DB Version: ccm7_1_5_10000_12
Number of replicated tables: 427
Cluster Detailed View from SUB (2 Servers):
                               PING              REPLICATION    REPL.    DBver&     REPL.    REPLICATION SETUP
SERVER-NAME    IP ADDRESS      (msec)    RPC?    STATUS         QUEUE    TABLES     LOOP?    (RTMT)
voip1    147.65.21.110    0.156    Yes    Connected    0      match    Yes      (2)
voip2    147.65.21.120    0.022    Yes    Connected    0      match    Yes      (2)
admin:
Processing ccmdbtemplate_voip1_ccm7_1_5_10000_12_1_410_devicenumplanmapremdestmap with 0 rows group 11
------   Statistics for ccmdbtemplate_voip1_ccm7_1_5_10000_12_1_410_devicenumplanmapremdestmap ------
Node                  Rows     Extra   Missing  Mismatch Processed
g_voip1_ccm7_1_5_10000_12         0         0         0         0         0
g_voip2_ccm7_1_5_10000_12         0         0         0         0         0
Processing ccmdbtemplate_voip1_ccm7_1_5_10000_12_1_409_devicenumplanmapendusermap with 0 rows group 11
------   Statistics for ccmdbtemplate_voip1_ccm7_1_5_10000_12_1_409_devicenumplanmapendusermap ------
options: q=quit, n=next, p=prev, b=begin, e=end (lines 2961 - 2980 of 3006) :
Processing ccmdbtemplate_voip1_ccm7_1_5_10000_12_1_403_batjobresults with 0 rows group 11
------   Statistics for ccmdbtemplate_voip1_ccm7_1_5_10000_12_1_403_batjobresults ------
Processing ccmdbtemplate_voip1_ccm7_1_5_10000_12_1_402_batinputdatajobmap with 0 rows group 11
------   Statistics for ccmdbtemplate_voip1_ccm7_1_5_10000_12_1_402_batinputdatajobmap ------
Processing ccmdbtemplate_voip1_ccm7_1_5_10000_12_1_401_batfileinfojobmap with 0 rows group 11
options: q=quit, n=next, p=prev, b=begin, e=end (lines 2981 - 3000 of 3006) :
------   Statistics for ccmdbtemplate_voip1_ccm7_1_5_10000_12_1_401_batfileinfojobmap ------
end of the file reached
