Cisco Unity 7 with MS Exchange 2013
Nahassamad_2
Hi All,
My customer is planning to upgrade their MS Exchange from 2010 to 2013.  I need to check whether it is compatible with Cisco Unity 7.0(2). Unfortunately i couldnot find any compatibility matrix from Cisco.  Can anyone help me please..
tonyperla
Here is the compatibility matrix for Unity 7 -
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity/compatibility/matrix/cuclientmtx.html
I also know that Unity 7 is not supported with Exchange 2013 and is EOL.
Hope this helps
Tony
Please rate helpful posts
Tony
tonyperla
Hope this helps
Tony
Tony
Hi Tony,
Thanks for the response.
I could not find the supported MS Exchange versions with Unity 7.0(2) in the above link. My customer need a proper document saying MS Exchange 2013 is not compatible with Unity 7.0(2) or a list of supported MS Exchange versions with Unity 7.0(2).
I am not sure if such a document exists.  Every document I see pertaining to Unity 7 and 8 only show support up to Exchange 2010.  You may have to just open a TAC case if the customer is wanting written proof.
Hope this helps
Tony
Tony
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity/7x/requirements/7xcusysreq.html#wp472166
java
if this helps, please rate
