06-19-2015 10:53 AM - edited 03-19-2019 09:43 AM
I need to check a bunch of settings and would like to avoid clicking around the GUI.
Is there a command or SQL statement I can run to find things like: Message Store, Class of Service, Alternate Extensions, Message Options, Template Configurations, Password Settings and Send Message?
Exact commands are nice, but pointers to useful documentation would be good too.
Thank you.
06-19-2015 11:07 AM
Why not use the User Data Dump tool instead??
06-19-2015 11:45 AM
I run Linux and it requires Windows.
06-19-2015 01:07 PM
The problem is that the actual tool that gives you the layout of the DB, is also a Windows tool
http://www.ciscounitytools.com/Applications/CxN/CUDLI/Help/CUDLI.htm
There's no data dictionary for CUC as far as I'm aware of.
06-19-2015 01:22 PM
It looks like I should be able to use the "show cuc dbschema database_name" and "show cuc dbcontents" to get the actual DB schema and data. According to the CLI documentation, the "unitydirdb" contains the configuration data.
So, the information should be available via the CLI, but I was hoping someone had some experience before I got poking around production systems.
