09-08-2015 07:23 AM - edited 03-19-2019 10:03 AM
Hello All,
I have small query,
is there self care portal like we have for CUCM to change Phone PIN password.
do we have same for unity connection to change the pin?
Lalit Arora
Solved! Go to Solution.
09-08-2015 09:05 AM
No, CUCM and CUC are separate systems.
09-08-2015 07:24 AM
Can WE use UC Selfcare portal, to reset VM PIN ????
09-08-2015 08:43 AM
PCA is here
https://x.x.x.x/ciscopca
09-08-2015 08:56 AM
Thanks Jaime
I am aware with pca.
However I need to verify about UCselfcare portal.
Can we reset the VM Pin using UC selfcare portal.
https://X.x.x.x/ucmuser/
Lalit Arora
09-08-2015 09:05 AM
09-08-2015 11:52 PM
Thanks Rob & Jaime for your inputs
so we can be sure, VM pin can be reset by end user by ONLY using PCA, not UC selfcare portal ?
Lalit Arora
09-09-2015 07:58 AM
Yes, as I already mentioned, they're different systems, not sure why you expected that.
09-09-2015 08:14 AM
Thanks Jaime for update
09-08-2015 09:01 AM
Hi Lalit,
As my friend Java nicely noted (+5) the User Portal for Unity Connection is called the Personal Communications Assistant or "PCA" the notes and user guide are attached below. There is no link to access the voicemail user configs via the Self Care portal as shown here;
And the section for resetting PINS/Passwords is here;
Cheers!
Rob
