Cisco Unity Connection After Recording
scr.sybex1
Dear,
I have cuc 8.6.
everything works fine but i want to konw is it possible to disable the promprt that the lady says after a user recodrd a voicemail.
i mean the prompt that lady says "for send press # or hang out for discard ....".
I want just user hear the greeting, and then record it voice and nothing say to user.
thanks.
I just played around with this for about 20 minutes and could find no way to disable the after recording menu options. That message is only heard if the caller stops talking after they have left their message and just waits in silence until that message kicks in notifiying the caller of their options for their message (i.e. send, modify, discard, etc.). Otherwise the caller should just hang up if they are done.
