Cisco unity connection web inbox error
Shaijala
I am getting  following error after login to Cisco unity connection web inbox
"Mail box could not be loaded"
I have checked following
- In user COS selected "allow them to use the Messaging Inbox and RSS Feeds"
- Inbox RSS Feed Service  -Service running
CUC Version 8.5
This is happening for all users  . Can any one help me on this
Shaijal
Rob Huffman
Hi Shaijal,
Is it possible that you are hitting this bug;
CSCty92204 - Exipred password Users logging into WEB INBOX not notified to change pwd
Symptom:
Inbox is not loaded for a user whose password has expired
Conditions:
When  password for a user expires,the user is not prompted to change  passowrd. The message shown to the user is "Mailbox could not be loaded"
Workaround:
The password can be changed through CPCA.The user can then navigate to inbox successfully
Details
First Found in:                          (1)
8.5(1)ES47
Status:
Fixed
Last Modified:
May 30,2012
Fixed in:                          (8)
9.0(0.98000.36),9.0(0.98000.138),9.0(0.181)
8.6(2.22028.1),8.6(2)ES30,8.5(1.15073.1)
8.5(1)ES94,1.9(9.98000.18)
Less
Product:
Cisco Unity Connection
Platform:
Dependent
Severity:
2 - severe
Maybe you could try changing one of the user "Web" passwords and re-test
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
Rob Huffman
Hi Shaijal,
Symptom:
Conditions:
Workaround:
Details
First Found in:                          (1)
8.5(1)ES47
Status:
Fixed
Last Modified:
May 30,2012
Fixed in:                          (8)
Less
Product:
Platform:
Dependent
Severity:
2 - severe
Cheers!
Rob
Many thanks Rob
