08-31-2011 02:29 AM - edited 03-19-2019 03:31 AM
I have a customer who is using the Click to Call 8.0 Widget.
They have contacts with the following numbers specified:
Business
Business 2
Mobile
Home
The Business, Mobile and Home numbers show up when I click the "Click to Call" toolbar button but the Business 2 number does not.
Is this a known limitation of the Click to Call widget? - if yes are there any workarounds?
On a related topic the C2C plugin seems to cause Outlook to crash on a few PC's. I am using the latest version available from the Cisco download site (8.0.2540.0).
This was released in July 2010. Does anyone have any suggestions for troubleshooting Outlook crashes? - there seem to be some Engineering Special versions mentioned on here - would it be worth asking TAC about these?
08-31-2011 03:06 AM
Hi James,
With regard to the Outlook Crash issue, you may be hitting the bug CSCtl57395 which is superceded by
.This bug is superceded Though it is in "release pending" state, I could see a couple of customers being able to solve this issue with the latest ES published by TAC.
I would suggest you to open up a case with Cisco TAC and let them verify if you are hitting this bug.
Please rate helpful posts.
Saurabh Agnihotri
08-31-2011 09:06 AM
Thanks Saurabh,
I will contact TAC and see if they can assist.
