Cluster to Cluster Dialing Problem
uddinabu1
Hi All,
I have configured two clusters: HQ and SB
HQ: CUCM version 11.0.1 and SB: CUCM version 10.5.2
I can call from SB to HQ but I can not call from HQ to SB
Note that both SIP trunks between 2 clusters are up and Full Service
Thanks in Advance for any suggestion why is not working for  both ways!
Jaime Valencia
And exactly what happens when you call???
What do you see in the screen???
What do you hear???
java
if this helps, please rate
Display  Unknown and hear:fast busy
Note that i also configured URI dialing between clusters and same thing happening...
I can call from SB to HQ but I can not call from HQ to SB using URI dialing....
Manish Gogna
You can start by checking Dialed number analyzer to see if the call is hitting the correct route pattern. If that is confirmed then collect detailed callmanager service traces for a test call.
Manish
