CM 4.1 incoming call tagging
peter_lengyel
Hi everyone,
I've been going through CM features but I couldn't find one that would match my need: we recieve calls from dozens of partners on a daily basis, and it would be neat to know who's calling before we answer the call. So, what I would like to do is adding a tag to a number, which would appear when that particular number is calling. For instance, make 555-9817 appear as "John Smith". Is there any way to make this work? All help is greatly appreciated, thanks in advance!
Peter
Jaime Valencia
unfortunately the capability is not in CUCM
if this is a call center consider IPCC for the deployment
javalenc
if this helps, please rate
java
Jaime Valencia
javalenc
java
That's what i was afraid of... thanks for the quick reply!
Peter
chris.fortner
Are you not getting caller id information? IE name display of calling party? You could send this to a translation pattern and change calling party information. Not sure if this might be an option for you?
hi Chris,
anything that doesn't require further investments is an option for me :)
what exactly shoud i do? can you give me some sort of documentation about this? thank you!
