CM - Generate Report of Gateway settings
Alex Rich
We are noticing some inconsistencies in how the h323 gateways are configured in call manager. Is there a report I can run to show what settings are selected so I can review them all without having to go through them all manually?
Thanks!
Jaime Valencia
No report, you could try using the export/import option
java
if this helps, please rate
