CME IP Phones not registering
Jagadish2
We are seeing ip phones are not registering to CME. Please help attached the sh run config file.
M02@rt37
Hello @Jagadish2,
Please provide us debug ccsip messages command during a sip phone attempting registering.
Note: you have 2 default route on your config ??
ip route 0.0.0.0 0.0.0.0 182.72.211.133
ip route 0.0.0.0 0.0.0.0 10.200.151.1
Thanks.
Best regards
5 Replies 5
Leo Laohoo
Are the phones getting valid IP addresses or not?
IP Phones are not getting IP address also..
Did anyone check the DHCP server?
M02@rt37
Hello @Jagadish2,
Thanks.
Best regards
@Jagadish2 As noted above your router config has some things to look at. As for DHCP, you have a pool for your phones, but it is not configured. At a minimum you will need the following. Modern IP telephony networks also should have a DNS reference and a domain, and I see neither in your config anywhere (which is surprising since you have an RSA key generated).
ip dhcp pool phones
 network 10.200.151.0 255.255.255.0
 default-router 10.200.151.10
 option 150 10.200.151.10
 dns-server x.x.x.x
 domain-name yourdomain.com
If you have have not already done so, please read the Cisco Unified Communications Manager Express System Administrator Guide
Maren
