CMSUB Cisco DB Layer Monitor Not Running
fdharmawan
Level 4
Level 4
Hi Guys,
I want to change the current CM and IM IP address to another subnet. To simulate of what I will do, I built a test environment. After the IP address change, the IM servers looked fine. The dbreplication status was 2. But CM servers got different story. The status was db admin dropped. I tried dbrep stop, dbrep dropadmindb, then dbrep reset all. The status changed to replication not started on Pub, and Cisco DB Layer Monitor Not Running on Sub. When I issued utils service list, the service itself is running.
I issued show process search dbmon, but did not find the database process, only root. So I started the DB Layer Monitor again then reissue the show process search dbmon command. This time the database process is listed. Then I issue dbrep runtime command, the replication status was the same as the publisher. But after waiting for several minutes, the dbrep runtimestate back to the service not start again and the dbmon process disappeared again. I do this repeatedly and got the same result.
Do you guys ever encounter this? My environment is 11.5SU9 btw. Thanks.
0 Replies 0
