Collaboration Edge - External SRV Records not resolving
Network Admin
I am in a testing environment. I am testing Collaboration Edge with Expressway Edge and Expressway Core.
Please find the attached Screen Shot
 _collab-edge._tls.company.com is not resolving while expe.company.com and company.com is resolving.
What could be the issue ?
Gordon Ross
Level 9
Level 9
nslookup (& dig) by default don't lookup SRV records. You have to add an extra parameter to specifically lookup SRV records:
$ nslookup -type=SRV _collab-edge._tls.example.com
or
$ dig _collab-edge._tls.example.com SRV
GTG
Please rate all helpful posts.
Jaime Valencia
It seems you can only resolve hosts, ask godaddy if there's something else you need to have those SRVs working.
java
if this helps, please rate
Gordon Ross
Level 9
Level 9
or
GTG
Network Admin
@ Gordon Ross
You Were right. I was missing the right parameters for lookup command.
It was showing up with below command that you mentioned.
Thanks Gordon Ross  :)
