01-09-2014 05:41 AM - edited 03-19-2019 07:43 AM
HI, I'm at the step where I'm creating a UM Service to access Exchange from UC. It asks to decide which options to select Message Action for Email. I'm wondering the difference between Relay and Accept? I understand Relay will need a smarthost setup, but i wonder when you use one over the other? We have Exchange 2010 sp3 RU4, and i've installed the latest UC 9.1.2. I'm currently using Unity 8.x so i'll be doing a Flash cutover soon using COBRAS tool.
Thank you.
01-09-2014 07:21 AM
Hi Robyn,
This doc explains the settings for you:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/gui_reference/guide/8xcucgrg085.html
Jump down to "Message Action for Email" section
Hope that helps,
Brad
01-09-2014 12:02 PM
So for Single Inbox setup, is Relay the better option?
01-09-2014 12:26 PM
Yeah, that's the most common since users don't usually prefer email sitting in their voicemail box on Unity Connection.
01-09-2014 06:42 PM
You should select Relay but if you setup a recipient policy in Exchange to alias with the SMTP domain name of the CUC node/cluster then you'll find that's likely all you need. There are some caveats on that depending on the environment but take a look here:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/ps12506/ps6509/guide_c07-728014.html
Brad - whats up old friend?
Hailey
Please rate helpful posts!
