Create custom script for play right language based on country number
Adriaan Mol
I want to create a script for the cue where i want to compare the first digits of the calling number to a predefined number, example someone calls from holland then the calling number = 0031xxxx , than i want to play a dutch prompt. , if the caller calls from germany 0049xxx then i want to play a german message.
I receives the callingnumber from the function "Get Call Contact Info" (string). Then i create several variabele strings with 0049 , 0031 , now i want to create a expression thats compare the predefined variabele with the first digit from the call contact info, but i dont know how to create the right expression,
Maybe anyone can help me ?
Adriaan
I think the previous post didn’t add he pictures right. Here it is.
Please split the Incoming Number to get first 4 digits and then depending on the first 4 digits, set the appropriate language message setting for call flow.
The individual steps are as below:
1) Create New String “Calling Num”
2) Get Call Contact Info
-- Get Calling Number details (Ex:1033xxx) and save it in “CallingNum”.
3) Create New String “GlobalExtension” as shown in step 1 and set value as CallingNum.substring(0,4). This will set first 4 digits of calling Num (Ex:1033) only to “Global Extension”.
4) Create New Language variables (English , Japanese , French ) and assign L[en_US] , L[ja_JP] ,L[fr_CA] respectively as shown in step1.
5) Add Switch Block to switch to the Langauage based on value of “GlobalExtension”
6) Add Set Contact Info Block: To set the appropriate language for particular call flow.
If the value is “1033” , it will go to “English_l” label and have the language as English ( By set contact info) for entire call flow. Otherwise , if it is “5433” ,it will go to “Japanese_l” label and have the language as Japanese (By set contact info) for entire call flow.
7) You can have your own further steps
Note: All required languages should be installed in the system.
Hope that helps.
Gomahthy.
Sent: Friday, December 16, 2011 7:40 PM
To: Madhavi Cherukuri (kadiyala)
Subject: - Re: Create custom script for play right language based on country number
Cisco Communities <https://communities.cisco.com/index.jspa>
created by Gomahthy Ganesan <https://communities.cisco.com/people/gomganes> in Unified Communications - View the full discussion <https://communities.cisco.com/message/81003#81003>
keglass
Level 7
Level 7
Adriaan,
Have you tried posting this question to the Cisco Support Community?  The community offers great resources and content regarding custom scripts. Here is the link: https://supportforums.cisco.com/index.jspa
Hope that helps.
Kelli Glass
Moderator for the Cisco Collaboration Community
gomganes
Hi Adriaan,
The detailed steps are as below
    1) Create new String "CallingNum"
   6)  Add Set Contact Info Block: To set the appropriate language for call flow.
Note : All required languages should be installed in the system.
Hope that helps.
thanks,
Gomahthy.
Hope that helps.
Gomahthy.
Thank you very much. Indeed , this piece of the script  i need  "CallingNum.substring(0,4)". Everything you wrote is very helpfull
I create the script and it's working, now we have a satisfied customer.
