04-17-2009 07:00 AM - edited 03-18-2019 10:53 PM
I have Call Manager 4 and Cisco Unity 4. I want to create an auto attendant so that when users dial into the system they get a recording and enter digits to go to a department etc. I know how to set up the call handlers in unity. how do i point inbound calls from outside to the call handlers in call manager
04-17-2009 07:03 AM
Depends if you want it to directly to Unity or ring a phone first.
Basically for direct, create a CTI Route Point that forwards all calls VM. So if main number is x4000, put 4000 in the Extension field of the main call handler, or create a routing rule in Unity for anything come from 4000 play call handler xyz
04-17-2009 07:17 AM
Thanks will try
