CUAC SQL Installation
Siva chinap
Level 7
Level 7
Hi All, Could you please confirm for CUAC deployment, external SQL is supported or not?
As per the release note it's mentioned only local SQL installation.
b.winter
If the release notes only state local SQL installation and nothing else, then only this setup is supported.
