08-07-2011 01:06 PM - edited 03-19-2019 03:23 AM
we have installed a CUBAC and, after the initial 5 days of evaluation, we have activated the 60 days evaluation license.
Now, we have had issues to obtain the permanent license, so it won't arrive before the expiration of the 60 days.
Is there a way to extend again the evaluation license?
TIA and regards.
08-09-2011 08:51 AM
If you have the Cisco Sales Order number you can try reaching out to licensing@cisco.com to see if they can issue you a temporary license or give you the permanent code (usually they know it once the order is fulfilled). Short of that your Cisco AM is the only other option here.
08-24-2011 12:34 AM
I have noticed that on the web page
http://cisco-ac.arcsolutions.com/Use...movaltool.aspx
there is a "License Removal Tool".
When I try to launch it on CUxAC server, it first shows the MAC Address of the server, then it asks for a "Removal code".
I have three questions:
Thanks again and regards.
08-25-2011 09:34 AM
The License Removal Tool is something only TAC Engineers can properly use. So to explicitly answer your questions:
1) You can use this tool only if the Cisco Support Engineer deems you in need to remove a license.
2) This tool can be used to remove all licenses that exist on a system, even the 60-day eval. But this must be done by a TAC Engineer.
3) Only TAC Engineers can generate a removal code, but they are subject to a specific need for one.
Jason
