CUBE call per second and simultaneous calls
cheng.cathy
CUBE 4331 can support 16/Max 32 calls per second. Does it mean it can only support 16/max 32 simultaneous calls?
Need to confirm this to determine what model we should purchase
Thanks in advance.
Nope. This is the call setup rate which is different from number of active
concurrent calls.
In fact you can by 100 simultaneous calls license for your ISR4K (
FL-CUBEE-100(=) )
The only thing to consider here is your RAM as you might need to upgrade
your RAM if you use high number of simultaneous calls or use higher router
Jaime Valencia
No, that is, as the name implies, how many calls can be processed per second by the platform. Not how many simultaneous calls a platform can support.
Look at the CUBE data sheet for a table with sizing info per platform.
java
if this helps, please rate
concurrent calls.
FL-CUBEE-100(=) )
awentland
Hey Cheng,
Could you please share Cisco doc with us with a info that CUBE 4331 allows up to 32 CPS?
According to this official articles:
https://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/data-sheet-c78-729692.pdf
https://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/data-sheet-c78-729824.pdf
Cisco CUBE 4331 supports 8 calls per second.
Thank you in advance.
Best regards,
Adrian
WeNt
